Version 4.53.0 - 09/26/2023
- Improved export objects
Version 4.51.0 - 09/06/2023
Version 4.50.0 - 08/14/2023
- Parameter mapping
- Fixed bugs
Version 4.49.0 - 07/27/2023
- Improvements to reports
- Parameter mapping
- Fixed bugs
 Version 4.47.0 - 06/27/2023
- Fixed bugs
Version 4.46.0 - 01/06/2023
Version 4.45.0 - 05/17/2023
- Fixed bugs
Version 4.44.0 - 04/27/2023
Version 4.43.0 - 04/06/2023
Version 4.42.0 - 03/29/2023
- Error correction.
Version 4.41.0 - 14/03/2023
Version 4.38.0 - 13/12/2022
- Mapping parameters.
- Fixed bugs.
Version 4.37.0 - 29/11/2022
- Added Azerbaijani language.
- Improved repeater.
Version 4.36.0 - 11/17/2022
Version 4.35.0 - 11/07/2022
- Retranslation update.
Version 4.34.0 - 10/25/2022
Version  4.33.0 - 09/28/2022
Version  4.32.0 -09/15/2022
- English localization.
- Fixed errors.
Version 4.31.0 - 08/24/2022
Version 4.30.0 - 09/08/2022
Version 4.29.0 - 07/19/2022
Version 4.28.0 - 06/28/2022
- Added 2GIS maps.
- Added client roles.
Version 4.27.0 - 05/26/2022
- Fixed errors.
Version 4.26.0 - 05/11/2022
Version 4.25.0 - 04/26/2022
Version 4.24.0 - 04/06/2022
Version 4.23.0 - 03/24/2022
Version 4.22.0 - 03/02/2022
Version 4.21.0 -02/08/.2022
Version 4.20.0 - 01/18/2022
Version 4.19.0 - 12/07/2021
Version 4.18.0 -11/16/.2021
Version 4.17.0 - 10/12/2021
- Fixed errors in waybills.
Version 4.16.0 -09/21/2021
Version 4.15.0 - 24.08.2021
 - Design updates.
Version 4.14.0 - 08/05/2021
Version 4.13.0 - 06/12/2021
 - User setting of PDF format.
Version 4.12.0 - 06/07/2021
Version -  05/20/2021
 - New units icons.
 - Updated field registry.
 - Updated design.
 - Fixed errors.
Version 4.10.0 - 04/22/2021
 - Updated event log.
Version 4.9.1 - 04/12/2021
 - Search for SIM1 and SIM2.
Version  4.9.0 - 04/06/2021
Version 4.8.0 - 03/18/2021
 - Updated Speedings report.
Version 4.7.0 - 02/25/2021
Version 4.6.0 -02/10/2021
-Work of cash boosted.
Version 4.5.0 - 01/27/2021
 - Updated visual objects.
 - Errors fixed.
Создал(а) Андрей Калиновский 2022/11/22 11:41
