Change history
Version 4.49.0 - 07/27/2023
- Improvements to reports
- Parameter mapping
- Fixed bugs
Version 4.47.0 - 06/27/2023
- Fixed bugs
Version 4.46.0 - 01/06/2023
- Added a column with a set of engine hours values in the "Fieldwork" log.
Version 4.45.0 - 05/17/2023
- Fixed bugs
Version 4.44.0 - 04/27/2023
Version 4.43.0 - 04/06/2023
Version 4.42.0 - 03/29/2023
- Error correction.
Version 4.41.0 - 14/03/2023
Version 4.38.0 - 13/12/2022
- Mapping parameters.
- Fixed bugs.
Version 4.37.0 - 29/11/2022
- Added Azerbaijani language.
- Improved repeater.
Version 4.36.0 - 11/17/2022
Version 4.35.0 - 11/07/2022
- Retranslation update.
Version 4.34.0 - 10/25/2022
Version 4.33.0 - 09/28/2022
Version 4.32.0 -09/15/2022
- English localization.
- Fixed errors.
Version 4.31.0 - 08/24/2022
Version 4.30.0 - 09/08/2022
Version 4.29.0 - 07/19/2022
- Parameters mapping of CAN bus.
- Parameters mapping of passenger flow.
Version 4.28.0 - 06/28/2022
- Added 2GIS maps.
- Added client roles.
Version 4.27.0 - 05/26/2022
- Fixed errors.
Version 4.26.0 - 05/11/2022
Version 4.25.0 - 04/26/2022
Version 4.24.0 - 04/06/2022
Version 4.23.0 - 03/24/2022
Version 4.22.0 - 03/02/2022
Version 4.21.0 -02/08/.2022
Version 4.20.0 - 01/18/2022
Version 4.19.0 - 12/07/2021
Version 4.18.0 -11/16/.2021
- Building report by the photo on the map.
Version 4.17.0 - 10/12/2021
- Fixed errors in waybills.
- In reports “Daily fuel” and “Summary fuel” are represented separately - consumption by fuel level sensor and fuel consumption sensor. Earlier the consumption was considered a priority from a fuel consumption sensor if both fuel consumption sensor and fuel level sensor have been installed. Now the values from these sensors are represented in single columns in order to compare their values simultaneously.
Version 4.16.0 -09/21/2021
Version 4.15.0 - 24.08.2021
- Design updates.
Version 4.14.0 - 08/05/2021
Version 4.13.0 - 06/12/2021
- User setting of PDF format.
Version 4.12.0 - 06/07/2021
Version - 05/20/2021
- New units icons.
- Updated field registry.
- Updated design.
- Fixed errors.
Version 4.10.0 - 04/22/2021
- Updated event log.
Version 4.9.1 - 04/12/2021
- Search for SIM1 and SIM2.
Version 4.9.0 - 04/06/2021
Version 4.8.0 - 03/18/2021
- Updated Speedings report.
Version 4.7.0 - 02/25/2021
Version 4.6.0 -02/10/2021
-Work of cash boosted.
Version 4.5.0 - 01/27/2021
- Updated visual objects.
- Added work with external servers in mobile application.
- Errors fixed.
