Статусы клиентов
Статусы располагаются в столбце со значком https://lh5.googleusercontent.com/3etmzpu8DpWUWJnLeN2C7QANTEvNWlSaUWHHb3V1fRUk4FAD-vxeTQWSLFOWgIVl2IEcqKgLjVJ8ShSP6v1t7qNYiNdmSQtrXGlqQp9Od92BGy0qrNaBTh1zNZI_4xboC_oENVos7tOzqCuvSZ8 и имеют следующее значение:
https://lh3.googleusercontent.com/36lMkTc4iZYNk_xWdB824W5NRBNHIShu1TLzyUNJb5E6765SBpuRgcd2gEXEXsGAPiQW_e0PElgXZ_cH1GGiID8RiuYcH08q_m5M5KXsEEkGid072leHH54ZsRZ6WzMMhRY7c7yiSzC5d-IK4_4 - Новый;
https://lh3.googleusercontent.com/DtvzbChLryQuvlmsjv9gWAHoLTTPoJww_-LOvFUvCKK_pPX4STVnpwuS73tzvpMRKWkWO6IhjW4UBYcWR1tgmwqLZ3vhkrhPyEczf-IuZKeYaLr1_cjbW480N0uO96TRjK4TLZ6S3dy47JIXmEM - Потенциальный;
https://lh6.googleusercontent.com/s2Ul666GP2Ua2ffF9SMYDhI73tQtQ2QBDsP0G3U17EqfTRuaDcp3lwD3rj86v_Z3nMt3yNB8uKZEZb3XHTTz0wWDqc7T4MZw6LB6OuWxGEgvzhJJlBrB7act90Pgf_lddwZG1k3U4E4OsmNTka8 - В разработке;
https://lh6.googleusercontent.com/QVzvLram3qB24dJIMoVZ8fHB-VFVSzo4Rn2g4abBo-nV1Hsl8yfaeTWwg-BvnMqg4b_e5ZjJFXymAHH1Lfjq6fuWLk7ndd0n2mWnqEW1ZWEsQk2_9RQVGIrab0uXV0icvQXWMia6AqYUgSyJEBoD2XY - Тест;
https://lh4.googleusercontent.com/zXKJa9FsNHgQhczLKEpzN1JeeMrepuUAGtSobWlYu_4If_8L36UNzCcnUWMaF5o5OUkdrfdYM-4A7dgewnua4YPBqZDWNcepUKrItUDY6rJTOpPHBJ7vnYoFHByM97jCdztTI54x7S04nRek4Vw - На оформление;
https://lh4.googleusercontent.com/mK-J0J2mEmlKeNJZNpHfyOMdXAbGeAWwF5ZzTUtyj1VLyDnptz41oLHWHAkuaMBDHv08_bALycNa8ANulCWP2oWeQXFzv98n5WJkx-CTQz_66XNKV2fLfSlveRKEU7ZcjIOUDFP3bgcErrwwi6JymqI - Внедрение;
https://lh4.googleusercontent.com/6sASao-e4gW1WyPWKJ5tD3b-xMTWCp4sErcyWkPzMKMVAVwSxCDKoFd3gRW4nYyT-N7rBKR1oH52rZ0q4Ia-bIG5l1X8mqehCjJkD531zCg5YmlDncYQ6TpJEMxnFqySy99O8_RsXWzOqQ32H9M - Работает;
https://lh3.googleusercontent.com/qa17GN-7vm3vxizNxDnIHHS-5X0C_z-6MNyq7U-u1MLO13_-y7hAJB2-L2UYEn0b4fxEu0jd6gPUDh32GLyUNT2mvv3vv3voDANV5kYzkV7ygSnmHQkhSJ7akARrjkp4KPIsVEi1flTbgxCicmQ - Работал;
https://lh4.googleusercontent.com/mTLkdBCLN_pTHq6RNWmwykBQ_-zvhW5R7nxYVw3l6sMm8vml0jqq__GReSj0CmPJAXL3oVVqzSDFQ9tlrSlNENSB9KopoXy5PmpzeBwPNstydNmCrNANy-4uGPUIMz71xyhqn5HMYKiPRUYrL6Y - Потерян;
https://lh5.googleusercontent.com/CEzh1Fp4HthuDUrN4nSLQN5HkQ2KvC98CK2sKE4GTnKeNqrTdSFtukxM9BFPsZ2aebtfeAcEv5Y_5PX8MxAAdjCIdVWhKIiDt6cped6iJ3rnsLhKMklY0uMsPOMXEdVP8W35_AF-1_qzXiccWlQ - Отказ.
Для того, чтобы поменять статус клиента необходимо перейти в раздел клиенты. https://lh5.googleusercontent.com/zB_wR9MMRYqVJy7ODf67EH8tHMzGctSyCSwoR77jiLka7MneCdShlpUYbbGR1M1-7EWouRAo8_dDjssWlDHvUSo2IANjUrx73secmIDGt3Sox0A9e0UHxTDApqZcMoUAAidh6IKmIkMhoh6OtW7R9xc
Затем выбрать необходимого и нажать на значек его статуса. В всплывающем окне смены статуса, расположен список из которого необходимо выбрать следующий статус.
https://lh6.googleusercontent.com/J7UrFfT3lwWSbtbo4Nc5bWKlRCFsgSGIsFiuaK1fm21YPR-va5lpiBodpk-4Noxtz5ELoVGaaF3DBWiSI81_uYYWvaDDtm9dMkUYB_ULZ7k_Vp8wqk6PBAZ5vpz03XHII0tnVjcEsSm7xlbov9g
  • дата;
  • статус;
  • пользователь;
  • комментарий.
https://docs.glonasssoft.ru/lib/exe/fetch.php?w=30&tok=ebd706&media=attent.png - ​​Стоит отметить, что заполнение поле комментарий является обязательным.
Последним действием нажимаем на кнопку “Сменить статус на…”
https://lh6.googleusercontent.com/Y2JpOhivvuRGsUfhEYaeKZyKdnfhgTVycdswIvd4WaHWt-a5Hy4BmCV2jXKbeVdFgKrAF83b2wIKDdfmRMvdAD9uBQ1Kh5xS6gTXRzVWWsvbGfLFN683CbFMvHSuqabskZ2Gr71RO0NT1UPxSy4QvSA
Новый - Потенциальный;
Новый - Отказ;
Потенциальный - В разработке;
В разработке - Тест;
Тест - На оформление;
Тест - Отказ;
На оформление - Внедрение;
Внедрение - Работает;
Работает - Работал;
Работал - Потерян;
Потерян - Потенциальный;
Отказ - Потенциальный;
Статусы геообъектов
Статусы бывают:
    Значение статусов:
    Отменен image-20220602150804-27.pngСтатус может присваивается технике на которой не установлено ничего, является признаком того что ставить оборудование не нужно на данном этапе или никогда
    Неисправен image-20220602150947-30.pngСтатус присваивается в случае если установленное оборудование работает не правильно по вине клиента, например УСС показывает неправильно из-за неисправного пистолета или ППО, при этом сам УСС установлен правильно и корректно. То есть фактически перевод в этот статус должен содержать предписание клиенту на исправление причин неправильной работы оборудования.
    Не эксплуатируется image-20220602151034-32.pngСтатус устанавливается в том случае, если объект не эксплуатируется, предлагаю рассмотреть установку данного статуса с автоматической отменой его на активный в случае поступления данных в движении или на дату
    Сервис image-20220602151341-35.pngСтатус сервис применяется для проведения сервисных работ, то есть если он назначен нужно проводить сервис
    Демонтаж image-20220602151356-36.pngСтатус присваивается если в момент проведения сервиса демонтируется оборудование (не заменяется), указывает на то, что работы не выполнены
    Дозаказ image-20220602151113-33.pngСтатус дозаказ используется если клиент хочет установить доп. оборудование на объект
    Смена статусаКомментарий
