Version 2.16.0 - 11/27/23
- Implemented functionality for managing map layers
- Created a "Notifications" section
Version 2.15.0 - 09/27/23
- Technical update
Version 2.14.0 - 08/09/23
- Improved display of parameters
- Other fixes and improvements
Version 2.13.0 - 08/01/23
- Added data on current mileage and engine hours in the "Info" section
- Adaptation of the application for iPhone 14
- Bugs fixed
Version 2.12.0 - 06/26/23
-  Kazakh language support
- Localization for the Yandex maps layer
- Refinement of the line
- Error correction
Version 2.11.0 - 04/17/23
- Added a "Ruler" option in the "History" window of the native application.
- Limited to max. x1.4 magnification
- Improved translation
Version 2.9.0 - 11/30/22
- Added Azerbaijani language
Version 2.8.0 - 11/14/22
- Change of windows layout
-Optimization of loading of units list
- Fixed errors
Version 2.7.2 - 11/01/22
- Technical update
Version 2.6.0 -09/30/22
- Added opportunity to change the displayed sensor type in the unit’s card. Now it’s possible to display data on mileage, engine hours, temperature and other sensor types
- Reports in mobile application now display all reports available to the users
- If data on the sensor is missing, the sensor is not shown instead of previous “No data” display
- Available option “Display latest valid data”
Version 2.5.0 - 09/16/ 22
- Opportunity to build route by the chosen unit
- Choice of the way of location display
- Settings in mobile application
Version 2.4.0 -08/15/.22
- Added new function of copying coordinates
- Added tool “Ruler”
- Added routes
Version 2.3.0 - 07/20/22
- Added 2GIS map layer
- Track display without enabled ignition
- Updated statistics work of mobile application
- Fixed errors
 obile application
 - Fixed errors
Version 2.2.0 - 05/30/22.
 - Added choice of a unit from a group with maximum zoom
 - Fixed errors
Version 2.1.0 - 5/23/22.
 - Unified name of the fields in WEB and m
Version 2.0.0 - 04/27/22.
 - Added push notifications
Version 1.9.0 -25.4.22
 - Focus on events after changing maps
 - Added option to add a unit
Version 1.7.0 - 03/29/22
- Added track routing
 - Added movement directions
 - Added annotation to the track
Version 1.6.0. - 03/10/22
 - Added fuel consumption in the section Statistics
 - Configuration of focus on the track when changing the map layer
Version 1.5.0 - 02/11/22
 - Configuration of vertical orientation of the application with display of units on the map
 - Added support of working with maps on Huawei smartphones
 - Optimized work of OpenStreetMaps in application
Created by Андрей Калиновский on 2022/12/05 15:51
